Several customers have recently had problems with uninstalling old versions of the SketchUp Octane plugin when new versions are installed. This is caused by an incompatibility between the old and new installer builds, which we can't fix just by changing the new installers (and we can't change the old ones because our time machine is in for repairs). So what I've done instead is create a small utility you can run if you're having uninstall problems:
https://render.otoy.com/downloads/ba/63 ... lugins.zip
This will simply remove all existing SketchUp Octane plugins from your system, along with their uninstall database entries, leaving you with a clean slate so you can install a new plugin without any problems with existing ones. This will only touch the Octane plugins, it will not change anything else in your SketchUp installation. You will need to run it as Administrator; it can be run either from Windows Explorer (right click, choose "Run as administrator"), or from a command line window that has been opened in administrator mode.
For people having uninstall issues
CaptainCrowbar wrote:Several customers have recently had problems with uninstalling old versions of the SketchUp Octane plugin when new versions are installed. This is caused by an incompatibility between the old and new installer builds, which we can't fix just by changing the new installers (and we can't change the old ones because our time machine is in for repairs). So what I've done instead is create a small utility you can run if you're having uninstall problems:
Thank you mate.
That works perfect.
cheers
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
- fivebythree
- Contact:
What the hell is going on. Used this app, now no versions the plugin are installing!
V2 I guess?? It is imperative this finish this project tonight.
STANDALONE+STUDIO WIN11PRO | RTX3090 | XEON 4210 20 CORE | 96GBRam
- fivebythree
- Contact:
NOPE, that didn't work either.
Says launching installation, doesn't complete the installation. Window comes up launch application.
