World environment rotate
mib2berlin
Hi, I am sure this was working at some point but now I cant get it to work.
I try all transform nodes, add projection modes or not, it only distort the texture.
May somebody know the actual workflow, it change several times and manual is outdated.
env_test.blend
(473.87 KiB) Downloaded 203 times
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
voon
viewtopic.php?f=32&t=45553&p=227672&hil ... te#p227672
Look at this further down ... the explication about sizes etc. I remember I had to use really small values for the rotation or it would rotate it so often fully that you see no change. Does this not work for you?
mib2berlin
Thanks voon, this is working, kind of.
You need a calculator if you need 45 degrees. :lol:
Cheers, mib
Return to “Blender”
