Hello Paul,
small thing :
would it be possible to increase the time the tooltips are visible when hovering over a value and alike? Right now they are barely there for 3 seconds, I would prefer that they would just stay there, until the mouse is moved again... if that's not possible they should at least remain longer, maybe 10 -12 seconds
best
Andreas
tooltips disappear to quickly
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
Hi Andreas. The C# .NET GUI is unfortunately very limited in the control you get over the tooltips for tree nodes, so it is not trivial to change the display time. It can be done, but involves changing the tree control in a way I would prefer not to do at this stage. Sorry.
OK, it is not that important. .. I thought it would be an easy fix like changing a parameter...
Never mind
Never mind
You would think - but not for a tree control tooltip. They are hard-set to 5 seconds.
Or we could just gather all of them tooltips into some pdf or sth and voila
You could probably write a simple LUA script to dump the tooltips from each node type in Octane Standalone. Would be a 2min coding job for an LUA guru.
