Sound & LiveDB
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Yambo
Hi Ahmet,
Sorry if this was mentioned before but i'm a bit busy in the past weeks with your great plugin and there is few issues that i would be really happy if you could take care of, so:
- If you downloading material from the liveDB sometimes it stuck on downloading. Then, if you moving to another window and coming back to the liveDB - cinema immediately stuck. This happens a lot.
- Second is something i've open a topic about before and i'll put it on the table again because i think it something easy to fix - Every time you sending scene to the live viewer while you have sound effector in the scene - sound start playing, Thats annoying if you working a lot with sound like i do.
- Last thing, i don't know why but cinema stuck a lot while working with octane (even through night while rendering) i don't know why but it worth mention, i'll try to investigate it.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Yambo wrote:Hi Ahmet,
Do you have that's not caused by a Cuda Error. If so i don't have any solution. You should care of this to don't cause it.
Yambo
It is not because cuda error. i had the cuda issue before if you remember and it was something with displacement and bad polygons.
Now c4d just stuck sometimes during night renders and stuff. I now you cannot help me without some error or indication, i'll try to understand it more.
https://yambo.me
try to disable computer to enter sleep on night.
Also have you had some time to check AE plugin?
Yambo
I just PM'd you ;)
https://yambo.me
Return to “Bug Reports”
