Render Queue // working or not
stoiqa
We have two stations with 4 and 4 titans in them, I submitted 7 scenes to render overnight, small changes/updates.
I enabled network rendering on octane render settings, but the other machine wasn't starting, although was connected and live preview was working and rendering in picture viewer was also using both machines.
Should I just use Net render?
Also any ideas on a render farm would be helpful...tried orc, but is not available.
[Not being able to use render queue in production, and not having a render farm available for big projects, puts a little shadow on the pretty renders ;0]
do you mean that client was working when you start a anim. render in picture viewer but not in render queue job? Have checked the client for crash/error outputs?
Also always give the versions. Each one is different, we can't know else.
stoiqa
aoktar wrote:do you mean that client was working when you start a anim. render in picture viewer but not in render queue job? Have checked the client for crash/error outputs?
Correct (not in render queue) // no crash errors. Had to submit half and half. We are using 2.16
It's an old version. Render queue should work as others. There is not big differences against Picture Viewer.
