Motion Blur Crashes Batch Render
ruhi
Without MB, maya batch render working.. But when i'm try the both options of motion blur with several settings, batch render crashes without rendering any frames.. Any ideas guys?
Could you give me the scene where you have this problem?
moviola
I have this problem with every scene. As soon as motion blur (internal) is activated, the Batch Render fails.
pixerati2
I think this might be the issue, according to the render log:
Error: Internal motion blur animation with "After" direction and 0.021 shutter requires 1 extra frame(s) after the animation's end frame.
I get this regardless of where I set the last frame to render...?
pixerati2
In your case - if you have e.g. 1000 frames in the scene, you can only do the rendering of first 999 frames. The last frame will only be used as a "tail" - for motion blur of 999th frame.
Refracty
You could probably fix it by adding an extra keyframe at frame 1001
pixerati2
Even if I render a subset of the center of the timeline I get the same issue.
I will check it.
ruhi
JimStar wrote:Could you give me the scene where you have this problem?
yes jim i'll send you scene by pm.. it's a bit heavy scene includes car crash sim. Includes gb's of sim data but i hope scene file is enough for your opinion huh?
ruhi
Aaaaand.. no answer..!!
Return to “Autodesk Maya”
