Multiple UVs workflow.
Maestrorobertus
I found the way how the 3 UV channels are support a bit painful. Just in case you have complex scene with presets you can get a lot work adjusting them.
So I would like to suggest an easier workflow.
Instead of leaving all to automatic item mode, and getting the user to order his items one by one. I would suggest to add 3 rows to the settings in which the user can define the names of the UV channels he want to use followed by a checkbox 'suppress error warning' because that one can be nasty.
So the slots could fill automatically when ever a scene is loaded, but the user can decide which to skip manual. Which is the way to go.
So Slot #1 is like always 'texture' and then the user might pick 2 more that he finds important to have, knowing that other may be skipped.
This would limit you to only 3 UV Maps for the entire scene, whereas the current implementation gives you an unlimited number. For example, at the moment you can have:
Mesh Item 1
- UV Map 1 = "Texture"
- UV Map 2 = "Item 1 Map 2"
Mesh Item 2
- UV Map 2 = "Item 2 Map 2"
- UV Map 3 = "Another UV Map"
Mesh Item 3
- UV Map 2 = "Item 3 Map 2"
etc.
What you CANNOT have is "Another UV Map" as UV Map 2 for Mesh Item 3.
Maestrorobertus
Oh.. so its 3 UVs per item, not 3 per scene.. somehow that escaped me. Well that makes sense. So basically if every item has the base UV channel it can have 2 more.. nice. I will check why I got errors before.
Not quite.....yes, it is 3 UV maps per item, however a texture locator might specify a UV map which is used by more than one mesh, and in this case Octane needs a UV Map "number" (not a name), so for both those meshes, they will need to have that UV map name at the same UV map index (ie. first, second or third in the UV map list).
Return to “Foundry Modo”
