Specular Conversion
LFedit
For some reason when I convert a material from a modo material to an octane override it is setting the specular to 1 by default. I have the latest plugin verison. Is this correct?
I also noticed sometimes it will convert the roughness to OVER 1.0 as well. Then you touch the value at all it will shoot back down to 1.0.
Thanks!
I assume you are talking about Glossy materials? If I convert a Modo Material with a Specular Color or 0.5, 0.5, 0.5, the Specular pin in the resulting Octane Override is 0.5. Is this not happening for you?
Thanks for pointing this out. I will fix it in the next release.
Greg
I think most MODO users would consider the specular amount (especially in MODO 901's physical material) the corresponding channel to the 'specular' channel in a Glossy Octane material. It doesn't really make sense in the context of the Octane material though (since it's expecting a color not just a single float) so I wouldn't change anything - it's just a workflow thing. MODO users using Octane should think in terms of specular color and not specular amount when the material is converted.
-G
CEO Sabertooth Productions
Co-Founder Pixel Fondue
LFedit
Greg wrote:I think most MODO users would consider the specular amount (especially in MODO 901's physical material) the corresponding channel to the 'specular' channel in a Glossy Octane material. It doesn't really make sense in the context of the Octane material though (since it's expecting a color not just a single float) so I wouldn't change anything - it's just a workflow thing. MODO users using Octane should think in terms of specular color and not specular amount when the material is converted.
-G
Yup you are correct sorry. I could have sworn it use to be the amount though. My bad, you can leave it the way it is.
Return to “Foundry Modo”
