Materials not rendering in Picture Viewer
michael.o'sullivan
Hi All
I'm having an annoying issue where my render is not displaying the textures that are applied.
http://imgur.com/ENoPUEF
As you can see on the link the left is the PV and the right is the preview window. The preview is displaying the texture on the clip however when I go to final render stage, the material is not rendering on the clip of the pencil model. Can anyone help and advise why this is the case?
Win 7 64-Bit | Geforce GTX980 & GTX750Ti | i7 5820k | 32GB RAM
Why annoying? Propably you are using a octane projection node which is based object space. It requires to export the meshes as movable. Because need to have transform nodes to display correctly! Right?
LV export all objects as movable if you have object tag or auto mode. But "Send all data" option in render settings ignores all this tranform nodes.
