Rendering in "Render Queue" only uses one GPU?
catoskogvoll
Hey!
As the title says, when I use the render queue it seems like Octane is only using one of my GPU's. It works fine when I render in picture viewer, and I've made sure that "Use all GPUs" in the render settings is enabled. I checked it by having two instances of GPU-z running and looking at the GPU load. Tried searching in the forums, but couldn't find anything. Am i missing something?
Thanks!
i7 2600k - 2x GTX780 SLi - 16GB RAM - 1200W PSU
I works as normal animation rendering. Maybe a problem but i dont' know. But this gpu usage is stored globally by plugin and should work as how you did in settings.
catoskogvoll
Hmm, I'll try some different setups and figure out where the problem might be then. Thanks for the quick reply
