OctaneRender™ for Blender 2.24.1 - 9.5 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed the F12 mode hair bug.
  • Minor fixes and improvements...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v9.5 Linux (99.7MB autoinstaller file)
DEMO is available..
Blender Octane Edition DEMO - v9.5 Linux (98.9MB autoinstaller file)
viewtopic.php?f=24&t=50202
mib2berlin
Hi JimStar, testing new version now.
For a long time the Server start after installation is finished, it start as root and therefor cant find a license.
It is not a big problem but you have to kill the process manually and start Server as user.
May you can change that in later versions of Blender for Octane.
Thanks, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
grimm
I have noticed a very large slowdown in the rendering speed on the newer versions of the plugin. I don't know if it's an issue with the plugin having to communicate with the server over TCP or if it's a bug. When you get up in polygon count (in my case it was around 2 million polys) the "evaluating render target" phase gets really slow and can take over a minute to finish. Once it's done the render happens very quickly at about 40 seconds. I was curious if this is a bug or it's just something we have to live with in the plugin? I haven't see these kinds of slowdowns with stand alone.
grimm
If you have the viewport in camera mode (numpad 0), switch to rendered, and then try and do a camera pan (shift middle mouse button) you loose parts of the view. If you then rotate the view and pop out of camera mode the lost areas stay and you can't get them back until you switch to some other display mode and then back to rendered.
Edited to add: If you go back to the camera view the lost areas are still gone.
grimm
If you copy a group of nodes in the node editor and then paste it into another object's node graph, Blender will not recognize the new nodes and the object renders black in the Material viewport mode. In the material tab for the object no surface node is shown. I then selected a glossy node from the pulldown menu. This created a new glossy node in the node editor. Then once I had connected all of the other nodes to it, they started being recognized by Blender in the Material viewport mode. I deleted the old glossy node. The texture renders normally in Rendered mode and if you do a full render, it's just the Material mode that is having issues.
grimm
I'm getting python errors from an addon plugin script about not being able to find numpy. I did some investigating and found the the numpy that comes with the Octane plugin is a symbolic link that doesn't resolve. I had to remove the link and copy the numpy directory from the official Blender 2.75a install.
zurkdahool
where do i find the sources (Blender/GPL related) i just want to modify some stuff for my personal use therefore i need to re-compile the 'octane-blender'
mib2berlin
Hi, source is on github:
https://github.com/JimStar/OctaneBlender
Cheers, mib
mib2berlin wrote:Hi JimStar, testing new version now.
Thanks, mib
Are you sure that you are starting the installation as non root user?
mib2berlin
I start installation as root, will try as user next time. :)
Thanks, mib
Locked
Return to “Blender”
