OctaneRender™ for Blender 2.24.1 - 9.5 Win [OBSOLETE]
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Added MS redistributable v120 to installer.
  • Fixed the F12 mode hair bug.
  • Minor fixes and improvements...
Blender Octane Edition - 9.5 (2.75) (67.7MB autoinstaller file)
Octane Server - 2.24.1 - 9.5 (10.4MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.23.2 - 9.5 (9.5MB autoinstaller file)
viewtopic.php?f=24&t=50202
justavisitor
JimStar wrote: Fixed the F12 mode hair bug.
THANK YOU, THANK YOU, THANK YOU!
I'm in tears! :mrgreen:
Latest OctaneRender for Blender. Windows 10, i7 quad 3.7GHz, 16GB, 2xTitan.
saikafu
nice work~~but still need hide emitter feature.........please add it ......
Balvarez
Awesome Thanks!
rz3x
Hi! Do you plan to merge the "Octane render layers" and "native" Blender layers? "Native" Blender layers is very understandable and intuitive, you can move the object by pressing the "M1", "M2", its quickly and comfortable. If i want to move object to octane layer i must open geometry properties and find a little button of number layer. This quietly, if you have one object. But if i need to move hundreds or thousands objects, I'll have to spend a lot of time on their movement.
Another argument in favor of the merging - the possibility of using a "native" blender laysers at compositing, which is currently supported only for octane layers.
Inciner
So sweet, thank you!!
Яussian engineer (AutoCAD+LISP/Blender 2.69/3dsmax/Mypaint/GIMP) | win7x64 + GT525m DELL || win8x64 16Gb RAM 2x GTX 770
justavisitor
Hi Jim,
I'm sorry, but the hair problems got worse in the latest update:
When I F12-render any image - except hair - the new version works as expected. But when I try to render a 'hairy' file, the render gets stuck here: "Elapsed: 00:17.01 | Render-target evaluation on server..."
At this point, Blender freezes permanently in a way I've never seen before: You can't force quit, and you can't start the task manager by clicking Ctrl-Alt-Delete.
So the only way out is to reboot.
I'll attach a screen-shot of my hair settings.
The latest Octane/Blender version where hair renders correct is 7.7. During the next versions, more and more hair systems disappeared from the 12 render (but they rendered fine in the view port).
I should add, that I have 8-10 different hair systems in each file.
justavisitor
This is not the bug.
You've just run out of memory resources during rendertarget evaluation due to huge amount of hair data.
Blender uses for live-view display the amount of hair-children set in "Display" field with max 5 vertices per each hair and per each child. When you F12-render them - Blender uses the amount of hair-children set in "Render" field with max 65 vertices per each hair and per each child. In your case only for hair-children this is 20 x 5 = 100 children-vertices per each hair for display (that your computer still handles), and 100 x 65 = 6500 children-vertices per each hair when you render it. That is - 65 times more. If you have the big amount of hairs consisting of 65 vertices each - having in addition 100 children per each hair consisting of 65 vertices each will definitely hang your machine if you have not enough memory.
justavisitor
JimStar wrote:justavisitor
Sorry, but it is a bug:
Again, version 7.7 F12-renders the image correctly in 3.5 minutes without any problems, what so ever!
The next versions also F12-render the image in about 3 minutes, but they leave out more and more hair-systems. And the latest version doesn't F12-render the image at all.
EDIT: I should add that I tried 3 different sets of Octane/Blender versions today - the correct one (7.7); the one I currently use (9.3); and the latest (9.5), one after another - to make absolutely sure that no other settings or factors could affect the results.
EDIT 2: You might ask: "Why don't you just use version 7.7 since it renders the file correctly?" Well, my problem is that I have to render animations. And version 7.7 has some animation bugs that you fixed in the following versions. So if I have to use version 7.7, I'll literally have to render thousands of stills manually, one by one. And that's not exactly my idea of fun... :mrgreen:
EDIT 3: I don't know if this helps, but when I render the image in vs. 7.7 or 9.3, I can hear that the machine is working because the fans start during rendering. However, the fans never start at all when I try to render the image in version 9.5...
justavisitor wrote:it is a bug
justavisitor wrote:version 7.7 F12-renders the image correctly in 3.5 minutes without any problems, what so ever!
If rendering 5 vertices per hair instead of 65 presented by current versions of Blender is "correctly" and "without any problems" - then you know anything better than me.
Your "bug" have appeared exactly due to the reason this was fixed in last version and now renders the correct amount of hairs, children and vertices-per-hair presented by Blender in F12 mode.
Locked
Return to “Blender”
