new materials
billyjoe2014
Hi, I just created some new materials using the grouping tool for several body parts and when loading Octane to test render and make any necessary adjustments, I repeatedly get the following python statements:
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 76, in Render
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 5178, in ShowSetupForm
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 184, in CreateNodesFromPoserScene
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 218, in ConvertMaterial
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 3579, in getSavedPoserNodeRoot
poser.error: A material with that name does not exist for this figure
Hi
Can you pls provide the info requested in viewtopic.php?f=45&t=42585. Particularly....
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Graphics Card(s) - model (ie. GTX 580, 3GB)
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- OctaneRender for Plugin version (ie. X.XXa)
billyjoe2014
Hi, here are the specs:
Windows 8 Pro
32.0 GB
64-bit Operating System, x64-based processor
Nvidia GeForce GTX 760
Driver Date: 8/25/2015
Driver Version: 10.18.13.5582
Poser Pro 2014: game development version: 10.0.5.28925
OctaneRender v2
for poser Release Number: 2.23.1.48
thanks
May I suggest updating to the latest release of the OctaneRender for Poser plugin, and seeing if that fixes your issue.
billyjoe2014
Will do,
thanks
billyjoe2014
No, same error message and then the plugin hangs at "Working,,, Checking and Converting Materials, Please Wait...."
I checked the plugin version and it's now updated to the latest.
Essentially its a character wearing armor with multiple separate cr2s, but the armor dos not cover the entire body. The solution was to alter the body parts that showed with new material assignments, in this situation, a chainmail texture.
thanks.
Thanks. Can you pls post the new error msg (it will have different line numbers to the original msg - allowing me to trace into the line of code causing the issue).
billyjoe2014
Ok, here it is:
File "C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 5293, in ShowSetupForm
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 180, in CreateNodesFromPoserScene
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 254, in ConvertMaterial
File "C:\Program Files\Smith Micro\Poser 11\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 3651, in getSavedPoserNodeRoot
Hi Billyjoe - that error does not look quite right. I have recompiled the plugin and refreshed the 2.24.1.60 installer. Could you pls re-download and install it and provide the resulting error output here?
billyjoe2014
Hi, here it is:
Release Number 2.24.0.58
Just noticed that my version of Poser Pro 2014 has always been installed on the E:\ drive and the above message refers to the C:\ drive?
a screen grab of the message
Return to “Poser”
