Plugin not working
ricardobjerke
This is weird
I am having problems getting my octane 3ds max plugin to work. It works fine inside Octane standalone application, but inside 3dsmax it doesn't, and I always get stuck with a colorful square, even though it detects my GPU. Not sure why this is happening.
Here are some screenshots:
Here are the details:
Geforce GTX 970
Nvidia driver 355.82
3dsmax 2015
Octane Plugin v.2.04
Octane Standalone v.2.24.01
We have this project that has to be rendered as fast as possible so needess to say that any help would be extremely appreciated.
FIREGRADER
Visit our page and like us on Facebook! ;)
ricardobjerke
Help? Anyone?
FIREGRADER
abreukers
hi ricardobjerke, for some reason we can't see the images attached. Is your scene built in the standalone v2.24? your scene might be using some attributes that were only added after v2.04, you might try upgrading your plugin version. don't forget to back up the scene prior to upgrading just in case you want to revert.
ricardobjerke
Hi.
No, it wasn't. The whole scene was built inside of max. The only reason I exported to the standalone version was to check if there was something wrong with my GPU.
I already tried other plugin versions, without success and the same scene renders fine in other machines...
https://www.dropbox.com/s/ik9nng0j53946 ... e.jpg?dl=0
https://www.dropbox.com/s/n9btrz9jrvqlz ... x.jpg?dl=0
Any thoughts? :S
FIREGRADER
HHbomb
your samples are set to 0...
I had the same problem one time, I had set the sample to zero by mistake.
ricardobjerke
HHbomb wrote:your samples are set to 0...
Thanks for the heads up but sample is on zero because the plugin can't detect the GPU, therefore it didnt sample anything. :)
FIREGRADER
Return to “Autodesk 3Ds Max”
