Hi we recently switched from Max to Maya and this is something that eludes us.
How do you apply a linear workflow when rendering and batchrendering, and not using the IPR, in Maya 2016 and Octane? In the end I want to save out 32-bits or 16-bits files.
Linear workflow Maya 2016
- blackshore
Info: http://knowledge.autodesk.com/support/m ... C-htm.html
When you set it to 16Bit raw, the renderviewport must also be in 16Bit raw
- itsallgoode9
- Contact:
Thanks for your reply. Can you set the render viewport to 16 bit in Maya 2016 and if so, where?Info: http://knowledge.autodesk.com/support/m ... C-htm.html
Thanks man, will have a look
