Octane CRASH after saving a Material to localDB
asher
The crash happens as follows:
1.- browse for material on LiveDB
2.- Drag into Octane ( this downloads files from the LiveDB server into RAM )
3.- Click Save on the node, into LocalDB.
4.- CRASH !!!! ( but the material gets saved, oddly enough )
Latest version of Octane 2.24
Also, is there a better way to say download ALL materials from a category into LocalDB for later use? say, "save all Stones" into LocalDB????
GTX TITAN, TITAN Black, 780Ti
WIN 7/64
I7
Asrock Extreme 3 motherboard
This has been fixed in the 2.24.1 release just posted.
asher
wow you guys are quick! thanks
WIN 7/64
I7
asher
before i download the latest built. I noticed it also crashes if i am within LW plug in, and attempt to do the same, save the material, crashes LW ( only if it is a true Octane node material, not a LW octane material with LW nodes )
will the new build fix this? or does Juangon have to fix the plugin as well?
WIN 7/64
I7
I suspect you'll need the 2.24.1 version of the LW for the fix.
chouki
Hi, I'm experiencing exactly the same crash in the C4D plugin version, wich seems to still be in version 2.24.0
It even makes C4D quit
Any plans for a fix soon?
thanx !
macOS 12.3.1 / C4D 2023.1 / M1Max MBP / 64Gb UM
hellguy
There is a newer version of the Cinema 4D plugin available here ( 2.24.1 - R3 ).
chouki
Thanks a lot !
