IES Texture File Path - BUG
- 3dreamstudios
When I set a light to use an IES file and then open the scene back up it is adding an extra path drive to the location. See file...extra "x:\"
- Attachments
- iesfiles.jpg (17.64 KiB) Viewed 3304 times
Does not happen here, it works as expected.3dreamstudios wrote:When I set a light to use an IES file and then open the scene back up it is adding an extra path drive to the location. See file...extra "x:\"
Do you have the latest daily build?
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun
Yes, this bug should be fixed in the last daily build. Please download it and test again your scene. If you have problems with the last build, please let me know.3dreamstudios wrote:When I set a light to use an IES file and then open the scene back up it is adding an extra path drive to the location. See file...extra "x:\"
- 3dreamstudios
I had the latest a couple weeks ago! haha. I'll have to check when I get back to office what I'm on and download latest to double check. Glad it's fixed. Hadn't seen before but I hadn't been using IES much either. Thanks again.
- 3dreamstudios
It does appear this is fixed in the 24 release. Thanks!
