Texture Env 3D rotation Error
morphious2013
Keep getting an error from plugin when I try to rotate the HDR file in texture environment. Using 3D rotation, when I move the sliders I get the error. See attached screen shot.
morphious2013
Anyone???? :o :shock: :oops: :roll:
wimvdb
I leave UV transform at 3D Transformation
then set the Projection at Spherical
In the Sphere transformation I rotate the Y
That works for me
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
I can't tell from your screenshot exactly which slider from which node you moved - so I'm sorry, I'm not sure the issue. I tried to reproduce the python exception, but everything worked fine for me. If you want to rotate the IBL, pls refer to the manual. https://docs.otoy.com/#44Image%20Based%20Lighting
Return to “Poser”
