GPU VRAM Status Display Question
jayroth
The render stats display that Octane imprints on the bottom of the image frame showing VRAM usage for each GPU is confusing me a bit. I have three GPUs in my syetm, and the VRAM reads as 1.302Gb/3.764Gb/6Gb. The 6GB GPU never changes its value. Is this stat free RAM or used RAM?
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
the informations about the VRAM usage are:
Currently used by Octane / Free memory that can be used / Max GPU memory in theory.
You are roughly losing 1GB, probably because you have a GPU that works for both monitor and Octane or other applications are using CUDA ;)
jayroth
Great, thanks! Yes, I have two monitors plugged into the first GPU card. I am unaware of any other option for them :)
Now does that mean that ALL of the cards follow this VRAM allocation, or just the card with the monitors attached?
Unfortunately, losing VRAM has effect on all the system. The card with less memory always determining the max VRAM available. This is the reason why the best set up for working with octane is to have a dedicated GPU (iGPU, Quadro, one slot GTX) only for display and other GPUs only for rendering ;)
jayroth
Thanks for the information. I have read this elsewhere in this forum, but your answer was the clearest (for me).
I only have so many slots, and without water cooling, I don't think I want to put another into this box just yet. That said, VRAM-wise, I am not yet running into trouble, so, so far, so good...
