Still would keep me from having to reload everything after a crash if I forget
IPR Crash Between Layout and Modeler
- 3dreamstudios
It seems when I have the IPR window open and am switching between modeler and Layout I get a crash quite often. Is there something that can be looked at here or should I just shut down IPR when wanting to go over to modeler. I like to keep it open to reduce the load times on big scenes...but then again I guess it still reloads the scene if things have changed. *shrug*
Are you editing objects in the Modeler that are loaded in the Layout while the IPR is rendering? ... I have some recent reports about problems editing objects in the Modeler while the IPR is rendering or even in pause, usually if the Hub is enabled.
I am going to work in this problem and some other issues after my vacation. I'll be back on September 7
... stay tuned for a 2.25 plugin build and perhaps the first screen grabs of Octane 3 working inside LightWave along September
- 3dreamstudios
Yes it's while objects that are loaded into layout are being worked on in modeler with the hub enabled. Basically a quick change while IPR is up. I'll either pause or keep running the IPR flip over to modeler make change and come back to Layout...sometimes it crashes many times it doesn't. Can't resolve why sometimes it does...juanjgon wrote:Are you editing objects in the Modeler that are loaded in the Layout while the IPR is rendering? ... I have some recent reports about problems editing objects in the Modeler while the IPR is rendering or even in pause, usually if the Hub is enabled.
I am going to work in this problem and some other issues after my vacation. I'll be back on September 7... stay tuned for a 2.25 plugin build and perhaps the first screen grabs of Octane 3 working inside LightWave along September
Nice tease on Octane 3 with some screen grabs. Can't wait!
