Hello
I've been trying to make a geometrygroup with several geometries connected, using LUA.
But I cannot find the names of the geometrygroup pins, after some hours banging my head I was able to get the NT_GEO_GROUP to have more than 0 pins, but their names are a mistery to me...
Could someone show a example of this?
Kind regards
Filipe
Grouping geometries using LUA
hi,
here is a script prepared some time ago, I hope it could be useful also for you:
-- Creates a group node and connect to all the selected meshes
-- @description creates a group and connect to all the selected meshes
-- @author Beppe Gullotta, with the corrections of Thomas Loockx and the help of Slater Lewis
-- @version 0.2
-- @shortcut alt+9
-- get the current selection
local selection = octane.project.getSelection()
-- find all the meshes in the selection
local meshes = {}
for _, node in pairs(selection) do
if node.type == octane.NT_GEO_MESH or node.type == octane.NT_GEO_PLACEMENT then
table.insert(meshes, node)
end
end
-- only do something if we have at least 1 mesh
if #meshes == 0 then
error("at least 1 mesh node needs to be selected")
end
-- get the position of the selected node in the graph editor
pos = selection[1].position
print ("mesh node position =")
print (unpack(pos))
-- create a group node with the number of input pins equal to number of meshes
local objectGroup = octane.node.create
type = octane.NT_GEO_GROUP,
name = "group",
position = {pos[1]+25, pos[2]+75}
objectGroup:setAttribute(octane.A_PIN_COUNT, #meshes)
-- connect each mesh to the group
for pinIx=1,objectGroup:getPinCount() do
objectGroup:connectToIx(pinIx, meshes[pinIx]) -- we can use pinIx because #pins == #meshes
end- Attachments
- bg4d-connect-group-02.lua
- (1.31 KiB) Downloaded 1026 times
