copy settings node Render Passes
rappet
Hi Paul,
When copy the node 'Render Passes' from one Rendertarget to another it does copy the disable/enable settings,
but they do not work (not to be selected) in the Render Pass section of the Rendering Window (first TAb)
(plugin AC19 2.23.2.51)
Then when I uncheck and check them again, they do work again.
cheers,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Hi Jeroen - this is fixed in the next release.
