Scripted node graph to extract camera position
Forum for OctaneRender Lua scripting examples, discussion and support.
manalokos
Hello
I've been trying to make a scripted node graph to extract camera position and target position or other values as outputs.
This way I can connect an alembic camera to this scripted operator and connect the output nodes to a new camera where I can control the aperture.
But as I have no experience in programming in LUA for octane, I was only able to create an input and output for the nodes, but the connections I wasn't able to make.
Could someone show me how to do this?
Kind regards
Filipe
Goldorak
Thomas made one for me. I can look for it and post it here once I locate it...
manalokos
Thanks Goldorak
Meanwhile I'll keep trying.
manalokos
I spent the whole afternoon trying to make this work, finally I was able to get the results I was expecting...
The output shoud be a camera node but meanwhile I can connect the position, target, and focus distance to a secondary camera...
It has 2 inputs, one for the alembic camera, and another for another alembic camera to work as a focus point. It would be great if alembic import would get position of nulls into float output...
    local Aextract = {}
    local inputs, tex
    -- onInit function, this is called once in the beginning.
    function Aextract.onInit(self, graph)
        -- input and output infos
        local inputInfos = {
            {type=octane.PT_CAMERA, label="camara", defaultNodeType=octane.NT_IN_CAMERA},
             {type=octane.PT_CAMERA, label="foco", defaultNodeType=octane.NT_IN_CAMERA}
        local outputInfos = {
            {type=octane.PT_FLOAT, label="pos"},
            {type=octane.PT_FLOAT, label="target"},
            {type=octane.PT_FLOAT, label="focusdistance"}
        -- use these functions to set up input and output linkers. This will keep
        -- existing linkers so existing connections in the parent graph are kept.
        inputs = graph:setInputLinkers(inputInfos)
        local outputs = graph:setOutputLinkers(outputInfos)
        -- set up a node to give the graph some output value
        posnode = octane.node.create{ type=octane.NT_FLOAT, name="posicaocamara", graphOwner=graph }
        targetnode = octane.node.create{ type=octane.NT_FLOAT, name="posicaotarget", graphOwner=graph }
        targetvector =  octane.node.create{ type=octane.NT_FLOAT, name="pontodefoco", graphOwner=graph }
        focusdistance = octane.node.create{ type=octane.NT_FLOAT, name="distanciadefoco", graphOwner=graph }
        outputs[1]:connectTo("input", posnode)
        outputs[2]:connectTo("input", targetnode)
        outputs[3]:connectTo("input", focusdistance)
        self:setEvaluateTimeChanges(true)
    end
    function Aextract.onEvaluate(self, graph)
        local camara = inputs[1]:getInputNode("input")
        local posicao = camara:getPinValue("pos")
        local foco = inputs[2]:getInputNode("input")
        local target = foco:getPinValue("pos")
        print(posicao[1], posicao[2], posicao[3])
        posnode:setAttribute("value", posicao)
        targetnode:setAttribute("value", target)
        targetvector:setAttribute("value", {target[1]-posicao[1], target[2]-posicao[2], target[3]-posicao[3]})
        focusdistance:setAttribute("value",{ math.sqrt(math.pow((target[1]-posicao[1]),2)+math.pow((target[2]-posicao[2]),2)+math.pow((target[3]-posicao[3]),2)),0,0})
        print(math.sqrt(math.pow((target[1]-posicao[1]),2)+math.pow((target[2]-posicao[2]),2)+math.pow((target[3]-posicao[3]),2)))
      return true
 end
    return Aextract
here is my attempt but with just one input abc node:
FromABC2Thin.orbx
(4.21 KiB) Downloaded 1489 times
It takes the focal distance from the abc node and I had to add also the focal length for correctly matching between the two cameras.
It should work also with animated camera ;)
local ABC2ThinScript = {}
local mInput
local mOutputF
local mOutputD
local mOutputP
local mOutputT
function ABC2ThinScript.onInit(self, graph)
    -- create input linkers
    local inputs = graph:setInputLinkers
            type            = octane.PT_CAMERA,
            label           = "ABCcam",
            fromNodeType    = octane.NT_OUT_CAMERA,
            fromPinId       = octane.P_INPUT
    mInput = inputs[1]
    -- create output linkers
                type = octane.PT_FLOAT,
                label = "ABCfocal_length"
                label = "ABCfocal_depth"
                label = "ABCposition"
                label = "ABCtarget"
    -- create float value node that will provide the ABC Camera value
    mOutputF = octane.node.create
        type         = octane.NT_FLOAT,
        name         = outputs[1].name,
        pinOwnerNode = outputs[1],
        pinOwnerIx   = 1
    mOutputD = octane.node.create
        name         = outputs[2].name,
        pinOwnerNode = outputs[2],
        pinOwnerIx   = 1
    mOutputP = octane.node.create
        name         = outputs[3].name,
        pinOwnerNode = outputs[3],
        pinOwnerIx   = 1
    mOutputT = octane.node.create
        name         = outputs[4].name,
        pinOwnerNode = outputs[4],
        pinOwnerIx   = 1
end
function ABC2ThinScript.onEvaluate(self, graph)
    local inCam		= mInput:getConnectedNode(octane.P_INPUT)
    if inCam == nil then
    local inABC		= nil
    local inFov	 	= nil
    local inDpt	 	= nil
    local inPos	 	= nil
    local inTarg 	= nil
    elseif inCam ~= nil then
    local inABC		= inCam:getConnectedNode(octane.P_INPUT)
    local inFov	 	= inABC:getPinValue(octane.P_FOCAL_LENGTH)
    local inDpt	 	= inABC:getPinValue(octane.P_FOCAL_DEPTH)
    local inPos	 	= inABC:getPinValue(octane.P_POSITION)
    local inTarg = inABC:getPinValue(octane.P_TARGET)
    mOutputF:setAttribute(octane.A_VALUE, inFov)
    mOutputD:setAttribute(octane.A_VALUE, inDpt)
    mOutputP:setAttribute(octane.A_VALUE, inPos)
    mOutputT:setAttribute(octane.A_VALUE, inTarg)
    ABC2ThinScript:setEvaluateTimeChanges(true)
	end
end
return ABC2ThinScript
manalokos
Wow, so much different way to write the code...
There are so few examples of Lua scripted graphs that is difficult to learn.
This is good, but the software I use won't export the focus distance so I had to make the double camera hack.
hi,
this is my second scripted graph and probably my approach is not the best, better to wait for the Thomas' example for a correct reference ;)
prehabitat
Did Thomas' script ever turn up?
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
stratified
I think it's this one. If you want to inspect/modify the script you need to enable "Scripted graph development" in the application preferences.
camera-explode.orbx
(100.3 KiB) Downloaded 1474 times
cheers,
Thomas
prehabitat
Cheers :D
Return to “Lua Scripting”
