Hot Ocean Plugin
I believe it's 32-bit only. If you're running LW in 64 then it won't load.
I used it recently to create an animated displacement map, then applied the animated map to the water object in the main scene (back in 64 version).
Vote for Juanjo!
- NemesisCGI
Hot Ocean is both 32 & 64bit. The displacements work fine with Octane used it on a project myself.
Win 7 pro 64bit GTX780
Oh sorry. I'm using Mac. I have only found a 32-bit version for Mac. However if I'd known there was a 64 version for Windows I might have animated and rendered that scene in Windows only...
Vote for Juanjo!
- NemesisCGI
It's one very useful tool, but on big scale it starts to look repetitive.
For several months now I had forgotten that Denis Pontonnier has some excellent textures for animating water. I think I'm going to try them next time...
They're here: http://dpont.pagesperso-orange.fr/plugins/Textures.htm
Vote for Juanjo!
- 3dreamstudios
Can you elaborate on how you got Hot to work with Octane? I'm trying to plug it into displacement node and nothing seems to be working. I do have UV on the geometry which I know has to be in place for displacement. I've tried plugging into texture image as procedural etc...nothing that looks correct.
Thanks for any input.
- BorisGoreta
- Contact:
You can't plug anything into displacement node except a texture node plus the mesh needs to have UV.
use hot ocean to displace geometry, or if you use 2D hot ocean then use texture rasterizer.
- gordonrobb
You need to use it to displace traditionally in Lightwave. Then rounder that in Octane.
