Modo 801_ 999 error + 901 mangled geomerty
marchermitte
Hello!
I just added another gtx 780 ti watercooled to my rig and had to uninstall and reinstall (clean) newest drivers (I had some hickups ) I'm using a 750 ti only for display.
Now this is strange: when using Modo 801, no card is recognized in the cuda list, get the error 999 in the log file. Now if I use Octane for Lightwave, everything is fine. Same with the standalone.
I removed the octane 801 kit folder and installed the 901 (I have both 801 AND 901 installed)
Everything is fine in the cuda list, log is ok but I get strange problem with even a very simple primities test scene (all quads and triangles)
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
Modo901 SP1 totally broken the Render Cache API , resulting in the problems you are seeing. Go in to preferences and untick Use Modo Render Cache and all should be good.
marchermitte
Yeap, that fixed the problem...
Thank you! You reply even during the week end!!!
Marc Hermitte
Return to “Foundry Modo”
