When otoy will update and fix these problems ?
vfxman83
-Huge scenes crash
-Octane proxy crash
-Tiles maps don'T convert
-Vray2sided material doesn't convert
-Mesh and poligon limitaion
-Render is failed
There are octane bugs and big problems
when will you update and fix ?
one day i will give up the octane if these problems don't fix and ipmrove
you have to fix and improve
coilbook
we get tons of failed renders and cuda errors during camera movement (during camera motion blur) seems like MB causes to much pressure on video cards
Goldorak
coilbook wrote:we get tons of failed renders and cuda errors during camera movement (during camera motion blur) seems like MB causes to much pressure on video cards
Please send Jim sample scenes - best way we can help fix these issues.
CUDA errors most likely mean the hardware problems under high load - GPU overheating or weak power supply unit... In some cases - NVidia drivers bugs... So, there is rather nothing to fix from the plugin's side - but the scene and the detailed instructions of "how to reproduce" are the essential thing to find out what is the reason exactly...
But first of all - make sure you have enough power from PSU for all the GPUs, and good GPU cooling. E.g. I always rework the thermo-interface between graphic chips and their coolers right after buying (using good thermal compound). Usually they are not good enough out of the box.
vfxman83
i always update cuda driver and nvidia i have two titan black with cooler master 1000 watt gold plus psu cpu water cooling cooler master hafx case with good cooling
ok driver and gpu problems
why tiles map and vray2sided material don't convert ?
tiles is the very simple bitmap in 3ds max
Return to “Autodesk 3Ds Max”
