Cant find topic
Moderator: BK
bpzen
Hi there,
I read a post a while back about a setting that we could adjust in order to clear up indoor lighting in places wher eteh scene was dark, i get really granular fuzzy results using mesh lights and places that are not getting a lot of light. I don't want to ad d lights as ti blows out that area and looks unnatural.
Is there a setting i can mess with to help this ?
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
hi,
I think you are talking about the Sampling rate value of the emitter nodes :roll:
The sampling rate allows to choose which emitters will receive more samples, the value can go from 1 to 10000, if set to 0 the light has no direct light contribution.
birdovous
bepeg4d wrote:hi,
How about the 'Path Termination Power' in the kernel settings? Could that make the difference? Of course increasing sampling rate for mesh lights helps definitely as well.
Maybe the topic/thread in question is this one:
viewtopic.php?f=45&t=47788
Birdovous
Master: Core i7 2600K, 32GB RAM, 2x EVGA GTX Titan X (SC)
Slave 1: Core i5 4460, 16GB RAM, 2x EVGA GTX 1080 Ti SC2
Slave 2: Core i7 9700K, 64GB RAM, 2x ASUS RTX 2080 Ti
good point birdovous, I thought about the emitters themselves instead of the entire render...
Path Termination Power should be right answer, reducing the value, you loose some speed but the dark corners will be cleaned ;)
bpzen
:) yes thaks
Return to “DAZ Studio”
