Merge goes wrong :-/
Jorgensen
hi
this is not really an octane question, but sence this is the only forum i use, and i'm working on a octance scene i hope it's ok.
i have always used file>import>merge to insert furnitures in my models and it has worked flawless.
when i open the furniture file, everything is ok, but when merged, it's rotated and wrong scale when inserted :-/
the axis icon in the left buttom corner shows the same in both files, and the "units setup" and the "system units setup" is the same in both files.
does any know which button i should'nt have pressed? :-)
thanks
frostfx
Is your furniture linked to any dummy object?
3xGTX Titan + GTX 770 | i7-4820 | 64GB RAM
3D Animation and Visual Effects http://frostfx.ee/
Jorgensen
deleted
Jorgensen
not sure - it's done from ground up.
- drawn in sketcup
- exported as fbx
- imported into 3ds max
- adjusted textures
- save as
i will be happy if you could test the table
https://www.dropbox.com/s/6unki2le9you6 ... e.zip?dl=0
Return to “Autodesk 3Ds Max”
