Copying mutiple materials from one proxy to another
rappet
Hi Paul,
It would be great to be able and copying mutiple materials from one proxy to
This is an example I am encountering often;
I.e. I have an OBJ (say apple tree) and I also use a duplicate as a proxy.
One tree I want green apples, the other red apples, but all have the same material for bark, leaves and more.
first I set all materials of OBJ1 correctly with red apples, transparancy dor leaves and other settings
and then I want to the same settings for OBJ2 with green apples.
Now I have to copy material 1 from OBJ1 to material1 of OBJ2, then material 2, material3, et cetera.
Only with apples I cahnge the color or texture, and that is it.
It would be awsome to be able and copy all materials of OBJ1 and paste them at once to OBJ2.
Then this should also be possible if OBJ2 has alos more materials then OBJ1, but will copypaste only the mterials with the same name.
I guess it might be hard question, but asking is easy :lol:
Greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
s3d-weyrauch
It can be really a hard question for Paul. But I think, if you already had an OBJ, and if you already set good textures to them, why don´t you export it to standalone, save only the OBJ and Texture-Nodes as an OCS or ORBX?
I work always that way. If I buy or build a cool Object, I save different OCS versions (with green apples, with red apples), and I can forget setting the materials in AC forever.
In my opinion, the better Feature would be to see and edit the Nodes of the OCS/ORBX in AC. But it´s complex as well, beacuse if a node is changed, it should overwrite the OCS/ORBX. Or we should have the opportunity in AC to save the changed OCS/ORBX with different filename.
Paul, thanks again for the last features about GDL. I´m very busy with AC19 right now, Graphisoft made it not so easy for us. I will report, if I have something.
David
BIM team leader
Win 10 | ArchiCAD GER 23-24 | Octane Plugin for ArchiCAD
13 Licenses | Network Render over 12 graphic cards
Hi Jeroen - my apologies for not responding earlier - I somehow missed this post.
The copy/paste mechanics in the plugin does not work for multiple materials - so that could be quite difficult to implement. However you can save all the materials of a proxy to "Default", then when you next use that proxy those defaults will be loaded. Alternatively, using OCS/ORBX for proxies is a good solution to.
This is a really great idea - and relatively easy to implement (using the new NodeGraph window that Otoy recently provided in the API). I will investigate for the next release.
