Render pass incomplete
3skel
Hello, i have e problem when i use render pass.
The render stop randomly while finish one pass like in image that i attached. (now i can't upload .jpg forum tell me "Temporary folder could not be found. Please check your PHP installation." :cry: )
This problem came in more cases, i have the log file if you need.
Thank you for your work!
juanjgon
What version of the plugin are you using? ... yeah, the forum has problems today. You can send a test scene with this problem or the logs to my email: [email protected]
3skel
Hello, i have 2.2 stable version.
I send the scene now to your email, but the problem is on every scene with render passes. I tried to remove and install again Octane, but the problem not solve.
Thank you!
juanjgon
Are you using the network rendering, or you have only one system?
I have just received your email. I will try to reproduce this problem here.
3skel
Only One System.
Return to “Lightwave 3D”
