Goldorak wrote:
The 1.0 viewer can already play back any mp4 with LR or TB and other filename extensions that support stereo playback, just like Oculus 360 videos.
Great I didn't know that thanks a lot, I guess a video with the same size as the stills?. any advise on compress for the MP4
Goldorak wrote:
You can also add a background image in the JSON (e.g. a cube map) with 'background' pointing to an image file. You can also set fovh/fovy for the video so that it is focused on part of the view. For example, we can render 60 deg stereo at 2048x 1024 and splat that over a still cube map render giving you 60 hz video inside an 18K stereo cube map scene, even if the FOV is limited.
So basically use just one side for the animation right? interesting will have a try on that.
thanks Goldrak
