I made material with displacement map. Render is FAILED.
If i clear displacement map render is working. And when i make Box, then apply material with enable displace - all work.
Apparently the problem is in the mesh, but I did not get to solve it.
https://www.dropbox.com/s/5w75fk0ip9kyh ... g.jpg?dl=0
My scene Archive.
https://www.dropbox.com/s/vwqr7o1uhnxft ... r.zip?dl=0
Displacement Error
Had all sorts of problems with displacement and render failed.
My problem was 'realworldscale' ticked on meshes. I unticked it and checked the scale of the uv map and that fixed it.
I had to find all the objects in my scene which had 'realworldscale' and uncheck that option on any I found.
