Image->ColorCorrect->Environment **Broken**
- 3dreamstudios
I'm not able to adjust the HDRI Rotation of an image if I put a color correct node on the image before it's plugged into the Texture of the Environment:DayLight node. Could this be a bug or limitation? Would like to be able to color correct an image before being plugged into the Daylight Environment node.
- 3dreamstudios
Ok will give that a try...is it not possible to have the Rotation still work in the Environment node in this setup? Seems like a work around. But may just be a limitation of some sort. Thanks for the fix either way.juanjgon wrote:If you use the color correction node with a texture environment, you can adjust the map rotation with the texture node U and V translate parameters. It has the same effect.
