Exr format
Hello Juanjo, I have a problem with the file export. When I open the file exr, unlike PNG or TIF, the picture looks washed out and overexposed. It 'a normal thing?It states that it is the first time I try to use the EXR format.
Pc laptop | Corei7 at 2.8GHz | 16GB | GeForce GTX 980M 8 GB | 240 GB SSD | 500 GB 7200 Rpm| Windows 8.1 pro 64 |
Try to read about linear workflow & gamma correction, There are plenty of stuff on the web related this issue.
Shortly EXR is a high dynamic range imaging image file format and should be handle different from PNG or TIF as you mentioned. If PNG/JPEG gamma is 2.2 for proper display. EXR should stay at gamma of 1.0.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0
https://yambo.me
https://yambo.me
if you are using photoshop, try the proexr plugin, it is the easiest way to deal with multilayer EXR files in PS.
basically, it's the same plugin which is built-in into after effects for a long time.
http://www.fnordware.com/ProEXR/
cheers
markus
cheers
markus
Ok, I'm not understanding anything. ProEXR do not solve the problem.
I would just like to take advantage of the EXR format 32bit PS. Is there any tutorial or video? I apologize for the off topic.
- FrankPooleFloating
You really need to start with fully understanding the Linear Color Space Workflow. Google it and bone up. In one day you can totally have your head wrapped around it and be up and running.
thanks for the answers! I understand that I have to study a little !! However, the problem was solved by saving files in EXR untonemaped.
I also realized that the Linear Color Space is very important! Thanks again.
