my scene has quite a lot of textures, most are 1024 up to 3000 pixels. if i were to reduce most of them to 512 would that increase render speed? Was curious if size of textures affects render speed and if anyone else has tested this.
thanks
Do smaller textures render faster?
I don't think I've pushed Octane to the limit, nor made very intense scenes. But I have made some experience with 2D planes with textures.
As I built the scene, render times didn't increase nor decrease, regardless of how many objects (all though single poly with 2K textures) I added.
There were about 150-200 objects in the end.
One frame on a GTX 780Ti (at the clients computer) took about 3 minutes with motion blur and nearly no noise, using the path tracing kernel, and the scene lit by the Environment: DayLight node.
It resulted in very nice and soft lighting, but slower frames obviously. I needed path tracing for some special lights and illuminating objects.
Faster or more GPUs helped increasingly. Especially as part of the sequence were to be in a "lightning took the power" situation and only a flashlight would lit the scene, resulting in tons of noise. Same rendertime as with the 780Ti on two GTX Titans, resulting in less noise, fixed that issue.
Modo & LightWave 3D | Win 10 x64 | RTX 2080 Ti | Threadripper 2920x | 128GB
