LV not updating
Krakenistanbul
Hello,
The LV freezes and I get the below message in the log
Thanks in advance
FILE is not found:
Export materials time= 171.931 ms
Collect objects time= 20.744 ms
Meshes creation time = 6757.709 ms.
Sending to Octane engine time = 0 ms
CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
-> failed to bind texture to device memory (data5)
device 0: failed to bind data texture 4 of context 0
<<< Render Failure >>>
Octane update time = 1216.441 ms.
Octane update time = 0.004 ms.
Total export Time = 84564.523 ms
It's not updating because there is a Cuda error. Also total export time is 84 sec. It means there is high polygon counts.
Question to people who post cuda errors: Don't you make some some tests during scene creation process? This will give some idea how much vram and polygons you have and how are you close to limits. Also would help to optimise your render times.
