Hi
i have imported a sailing boat model from rhino in to lw.
I used obj to separate all the parts of the boat and used obj to load them in Lw.
When i try to render the hull in Octane i get strange triangles look on it..
If I render in Lw everything is fine.
It seems a vertex map problem but even if i assign the right vertex map or i delete it the "look" remain exactly the same"
I have tried also to merge and triangulize everything but it doesen't change...
Have you met this problem before?
I uploaded 2 pictures...
thanks for help
strange behaviour on imported object
it seems impossible to load pictures today...
FIXED!!!!
It was simply a scale problem, the model was very huge and not in the right scale...
