How to make imported mesh textures visible?
FAS
Hey Everyone,
Recently I purchased the OctaneRender plugin for MODO (OS X). Everything seems to work fine except that when i import a mesh with a few textures the don’t show up. It’s just a blank model. But al the materials and textures do show up in the shader tree. After reading the online manual it shoeld work after making a bunch of Octane overwrites an re-linking with nodes in the OctaneRender setup window in MODO. But no matter what I do, I can’t make it work.
For example this simple plant model; what do i have to do to make the alpha mask and the textures show up?
Thanks in advance!
Floris
I suspect that imported model has a Selection Set assigned to the material group. Clear this (change the Polygon Tag Type to Material, and Polygon Tag to All). I will probably change the plugin to do this for you by default in the near future.
Future to the above - pls see 9) at http://render.otoy.com/universe.php#42Limitations
FAS
Hey Paul,
Changing the Polygon Tag Type to material and the Polygon Tag to all indeed did the trick!
If these are the only things that I need to change than it’s not a problem. But as you said, if it could be done by default, that would be nice.
Anyway, thanks for the advice!
Floris
Return to “Foundry Modo”
