Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
- All Octane nodes now appear in new 2016 Hypershader search (TAB button).
- Added the light pass ID attribute to light nodes.
- Added "Constant topology" attribute to meshes. If it is not set for "Reshapable" mesh - Octane will not try to calculate the vertex motion blur for this mesh (if "Internal" motion blur mode is chosen).
- Now the plugin will use the vertices motion vectors for "Reshapable" meshes if the mesh has this data set (currently Maya sets this mesh data after being converted from fluids). This is for the "Internal" motion blur mode only. If this data is not present (mesh's "Motion Vector Color Set" attribute) - Octane will try to calculate the inter-frames motion blur for this "Reshapable" mesh as usual.
- Minor fixes and improvements...
DOWNLOAD
OctaneRender for Maya 2.23.2 - 7.8 (12.3MB autoinstaller file)
OctaneRender for Maya 2.23.2 - 7.8 Demo (10.8MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender™ Team.
