OctaneRender® for Maya® 2.23.2 - 7.8 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • All Octane nodes now appear in new 2016 Hypershader search (TAB button).
  • Added the light pass ID attribute to light nodes.
  • Added "Constant topology" attribute to meshes. If it is not set for "Reshapable" mesh - Octane will not try to calculate the vertex motion blur for this mesh (if "Internal" motion blur mode is chosen).
  • Now the plugin will use the vertices motion vectors for "Reshapable" meshes if the mesh has this data set (currently Maya sets this mesh data after being converted from fluids). This is for the "Internal" motion blur mode only. If this data is not present (mesh's "Motion Vector Color Set" attribute) - Octane will try to calculate the inter-frames motion blur for this "Reshapable" mesh as usual.
  • Minor fixes and improvements...
Installation:
DOWNLOAD
OctaneRender for Maya - v7.8 Linux (19.1MB autoinstaller file)
OctaneRender for Maya - v7.8 Linux DEMO (15.9MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Yours,
The OctaneRender™ Team.
matrix2012
Hi
Under Render Settings of Render passes: Post porcessing missing.
The Render Passes: post processing missing :(
Modo and Lightwave have to download the livedb.
So which one the livedb localdb folder in because can store and offline access has database for material.
Is it Possible to provide also in Maya.
Or a compressed file that can be downloaded and then decompressed in the localdb.
That would be great. :)
Modo exemple:
octane.command downloadLiveDb
sorry for my bad English.
Next version HERE.
Return to “Autodesk Maya”
