Hello, i'm having a strange problem rendering a frame sequence. I've set up a flocking system to simulate blood cells, if i scrub the frames slider they all show up and move correctly in the IPR window. When i try to render the whole sequence octane keeps rendering the first frame all over, so i end up with about 200 image files which contain the same image.
I'm using Lightwave 2015.2 and Octane 2.23.2.3
Any help would be much appreciated.
Frame sequence issue
If you are rendering in update scene mode, do you have the "update instancers" parameter enabled?
http://render.otoy.com/manuals/Lightwave3D/?page_id=155
- Bugstomper
That was it! thank you very much! I never noticed that option in the render target, my bad
