Alembic Cam Animation w/ Panoramic Setting
DarcFusion
I've imported a camera from Cinema 4d to Octance in Alembic format. My question is: How can I add panoramic settings to an alembic camera lens?
here is a simple Lua script for substitute the Alembic Camera Node with a Panoramic Camera node taking the same position and target of the original abc node:
FromAbc2Pano-001.lua
(1.59 KiB) Downloaded 449 times
You must select the Render Target node in order to run successfully the script.
Please, let me know if it works as expected,
little update with Keep upright and Side by side option enabled:
FromAbc2Pano-002.lua
(1.7 KiB) Downloaded 884 times
