Wish : more slidercontrol
v-cube
Hello Paul,
it seems I am in a "make a wish mode today" maybe you should reduce the wish / user ratio to one wish a day :-)
this one is probably an easier one:
would it be possible to adjust the slider interface of the rotation amount of hdris in a way we could better control the positioning of the sun ? I think it would probably be enough to double the length of the sliders, for me personally it would also be more logic / convenient to just have a range between 0 and 360 degrees, without negative values, since this would 100% describe the possible rotation amount without creating double identical settings like 90 and -270 which describe the same rotation amount and so just add confusion and waste "slider space"
thanks
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
newske
This would be nice :)
Maybe -180 to 180 with 50% more length? Wouldn't want them forcing the Octane panel to be wider (or have horiz. slider) but extra fineness in control would be useful.
Cam
Octane for Rhino | Windows 8.1 x64 | i7-3820 OC | GTX970 4GB OC & GTX 560 Ti 1GB OC | 32GB DDR3
prehabitat
Don't see any problems with this idea. Sounds great!
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
I have managed to get the sliders to stretch with the window, which will help a lot. I can put the range from 0 to 360 or -180 to 180. Pls vote which you would prefer :-)
Bendbox
I don't have a strong preference here, probably because I'm used to adjusting both positive and negative at this point, but my gut tells me that 0-360 seems to describe the action more accurately. If it's a spherical HDRI, 360 seems to make more sense.
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
v-cube
Cool!
0-360 for me please ☺
Andreas
Return to “Rhinoceros 3D”
