Hi All
I am sure I miss something, but mabe one of the Pro's can help me out: How do I safe a final render?
When I press the Final Button, the Plugin starts rendering. It looks great and after some Minutes, the Rendering has finished and Says:
1500 of 1500 s/pix in the Statusline.
But the "Save" button is greyed. There is a yellow Triangle, but I cant press it or nothing happens. So, how do I know when Rendering has finished and
more important, how do I save my final image?
Thank you very much and sorry for that stupid question!
Cheers
Beat
Saving Final Render
Moderator: BK
- larsmidnatt
what you are describing is a bug. It doesn't happen all the time (and I am pretty sure its new to this release of the plugin, as it never happened before). You should be able to see that it is greyed out right after you press the final render button. if it greys out don't continue with the render, if it doesn't grey out you are safe.
So options are:
Don't use final render, shouldn't ever see the issue.
Be sure to keep eye on save button if you choose final render, if it is grey don't let it finish.
Also consider using the "auto save as" feature. I have mine set to every 5 minutes right now. I think if you enable that before you press final render it will continue to save for you.
So options are:
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
i9 10900k 64GB
2080S 8GB
