OctaneRender™ for Blender 2.23.2 - 9.1 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Animated ORBX export is implemented.
  • Minor fixes and improvements...
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v9.1 Linux (99.8MB autoinstaller file)
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
Next version HERE.
Return to “Blender”
