Images on ORC
I'm using Octane as a part of my graphic design workflow. Currently I have a weakling little mobile GPU on my iMac, though Octane works surprisingly well for my purposes. I would like to start rendering much higher resolution images at higher sample rates. Will I be able to prep and upload a Cinema4D file (or something) to offload that rendering to your cloud solution? From what i've gathered ORBX is what ORC is currently accepting, which seems to be your cube map VR format.
						- Rikk The Gaijin
ORBX is just a container, kinda like a zip file.visua wrote:From what i've gathered ORBX is what ORC is currently accepting, which seems to be your cube map VR format.
You can use the free version of ORC to render non-VR images, but I think the resolution and the samples are limited.
I would expect Otoy to launch the full commercial version of ORC after the Metaverse contest has ended, so very soon.
