Object "disappearing" when rendered in ORC
Discussion forum for OctaneRender Cloud
Rikk The Gaijin
I have encountered a bizarre problem. One of the object in my scene does not appear in the ORC render, but it does appear when rendered in Octane Standalone. :?
I double checked both the ocs and the orbx files, and the object is there and works fine in Standalone.
To help the devs debug it, I made a scene that contains only the problematic object, (you can get it here: https://drive.google.com/open?id=0B42Mj ... WdwX1pLQnc)
Please check it and let me know what the problem is.
Thank you
therealjustlike
I've also had this problem, interested to hear an Otoy response.
i7-4770k, 16gb, gtx770
Rikk The Gaijin
I had no response so far... :(
Rikk The Gaijin
EDIT: The bug is fixed! 8-)
therealjustlike
Hi Rikk,
Does your solution require a new upload of your scene?
Yesterday after I read your post that it's fixed, I kicked my renders off again and today I see that
they are still not rendering my objects correctly. Did you do anything special to make it work?
Any insights would be appreciated. Thank you.
p.s. your entry to the metaverse contest is beautiful! :D
Rikk The Gaijin
Yes, unfortunately you need to re-upload the ORBX file.
therealjustlike
excellent, I will try that
therealjustlike
Screenshot 2015-07-31 09.54.30.png (18.98 KiB) Viewed 12537 times
huh. I uploaded my scene again last night to render and
I am still getting the same issue.
It's probably pilot error. :(
So were your objects always the same object the disappears?
The objects in my scene that disappears has a complex stack of modifiers on it
I double checked visibility tracks and they are normal, and not all of my
disappearing objects have animated visibility tracks.
Rikk The Gaijin
Oh, I use the Standalone version, I don't know how the 3DSMax plugin works, sorry... :(
Return to “OctaneRender Cloud”
