Solo/Isolate Items
RahiSan
Hello,
I just wanted to ask if someone knows a quick way to solo Items. Hiding everything but the item works of course, but this is very cumbersome.
In modo I usually use the command: "view3d.inactiveInvisible true/false" for this, but it does not work with the plugin.
Thank you.
This will potentially work if you have Preferences->Use Modo Render Cache enabled - however it is recommended you leave that setting off until some Modo901 bugs have been fixed. Otherwise, use the Mesh visibility for each mesh.
Return to “Foundry Modo”
