Octane tab opens all pins when rendering
splittmatt
Hi Paul
Is there anyway to stop all of the pins re-opening when I click 'open viewport'? I am mainly using Exposure and it's right at the bottom of the list so I have to close most of the other pins, 'camera, resolution, environment etc etc to get to the one I want. Having all the render passes pins etc opening all the time is really annoying.
Either that or having a way to re organise the pins so the users main pins can be moved accordingly?
Win 11. Intel I-9 14900K. 64Gb. RTX 4080 Super.
v-cube
good one ...
+1
Andreas
1 x 4090 GTX, 1 x 3090 GTX
http://www.v-cube.de
It necessary for the Settings tree to be rebuilt - however I have added an option to the Configuration of the next release to default the view to just opening the Rendertarget tree node.
splittmatt
Great, Thanks Paul.
formatio
Hi - regarding pins is there a chance to add option to disable/enable popup notifications when hovering on pins - I know them perfectly already and they occlude my view (also use precious gpu power) :)
Regards,
Mac
Hi Mac. I will add this to the next release.
Micha
Hi Paul,
please try to add that the tree stay like the user setup it. There a so much options and it helps a lot, if UI doesn't automatic reset. The current two behaviors (reset to expand/shrink tree) are not user friendly.
Ciao,
Micha
http://www.simulacrum.de - Visualization for Designer and Architects
Win7 64 | Dual Xeon E5-2687W | 32GB RAM | 2 GTX 780 6GB | Rhino3D
I'm sorry - but that it not a viable change. The Setup tree gets re-created from scratch when you open the Viewport to ensure the node structure matches the current version of Octane.
Micha
That's a pity, but on the the side, if Octane would be to much easy to use than my clients would buy Octane by himself and I had less projects as freelancer. ;)
splittmatt
Hi Paul.
The latest build (3.5.3.77) seems to open all the pins again. Is there a way to stop this?
Matt
Return to “Rhinoceros 3D”
