Do i have to upload as ORBX
Discussion forum for OctaneRender Cloud
coilbook
Once octane cloud is running do i have to upload the scene as orbx etc. Can octane cloud just add GPUs that I leased in my Network Config like my networked PC are detected Thanks
glimpse
Hi there.
For now You need to upload orbx package in order to rende in the cloud, but I read in these forums them about integrating cloud into application (guess somewhat simillar to how network rendering works now =)
Goldorak
glimpse wrote:Hi there.
Yes, we're testing this internally. and hope to have it out shortly.
coilbook
Thank you all!
JNDesign
Hi there
So will it work similar to say "GPUBOX" where the local computer sees the gpu's as available devices?
Thanks in advance
Goldorak
JNDesign wrote:Hi there
Thanks in advance
It will be more like a job manager that you operate from the SE or plug-ins. We are adding synching of data to/from the cloud service, so you don't have to upload a new ORBX every time or use the web UI to start a render job. ORC is great for larger jobs, for example you can have separate GPUs on the cloud rendering each frame of an animated sequence in parallel over hundreds of GPUs.
We also expect ORC to be super efficient for rendering VR, light fields and baking. One you render a light field scene, you can then pull down a new viewpoint automatically from ORC for example. So you can generate any camera path you want on the fly without needing to do a new render.
JNDesign
sounds awesome.....cant wait..
any eta?
many thanks again
Goldorak
JNDesign wrote:sounds awesome.....cant wait..
any eta?
many thanks again
It looks like the 2.0 update should be out this month. We'll let everyone know once it is published, and provide samples to get people going. Atfer that is out, we'll work on script nodes for Octane and the plug-ins that will export to ORBX media packages without having to write your own lua files.
JNDesign
great news
Could you clarify if in the end, we would be able to access the gpu's straight from the plugins? without the need to export etc
I mean would they be available as devices on our local machines.
cheers
Return to “OctaneRender Cloud”
